Configure Static Forwarding
Configure static forwarding to specify the group of ports that are allowed to forward frames.
Important
Entries are valid for unicast and for group/broadcast addresses.
- Select VLANs.
- Select the Basic tab.
- Select a VLAN.
- Select Bridge.
- Select the Static tab.
- Select Insert.
- In MacAddress, type a forwarding destination MAC address.
- In Port, select the ellipsis (...).
- Select the port on which the frame is received.
- Select Ok.
- Select Insert.
Static Field Descriptions
Use the data in the following table to use the Static tab.
Name |
Description |
MacAddress |
Specifies the destination MAC address in a frame to which the forwarding information for this entry applies. This object can take the value of a unicast address. |
Port |
Specifies the port number of the port on which the frame is received. |
VlanId |
Status |
Specifies the status of the VLAN. |
